"Hi & Thanks in adavance -
I have 2 fuel tanks -
* a 3 way valve to switch between tanks and
*an electric fuel pump (no primers and NO fuel pump in the engine(this is the way my mechanic set it up).
My problem is I cleaned out my tanks etc.. set it up and will not pump fuel. I have syphoned from the omc fiter hoses and the 3way valve is working and the lines are clear. I have a photo of my set up(easier than trying to explain it)@
http://i284.photobucket.com/albums/ll31/5_cougars_thanks/Untitled-1copy.jpg"
I filled the filter with fuel, left the fuel caps off - blew down the filler hose into the tank, blew down the breathers - but it still does not pump the fuel from the tanks. (the only thing missing is the O Ring from inside the fuel/water filter.
ANy suggestions would be appreciated.
Thanks peter"
Thanks peter"
