"Gary,
Well ya know there
"Gary,
Well ya know there is never a 100% guarantee to being safe.As for your situation you might get different ideas from different people.A few years ago I put new engines in myself and this is what I did.I wired the fuel pump that the ground became my switch as I wired it to my oil pressure.That way if an emergency happens or a fire starts,if the engine shuts off or you turn it off, the pump will not continue to put fuel to the fire.The only drawback to this is that when starting you only have the fuel thats in the bowl of the carbs to start. What I did was put in a bypass switch to a ground in case I needed more fuel to get it started.That was never needed in 2 years of early spring and late fall starts.Also prevents a problem of leaving the key in the on position running the pumps.Worked well for me and I would do it that way again....Todd"
