tigershark
"I have a 1995 88HP Johnson an
"I have a 1995 88HP Johnson and I suspect that the Electric Fuel Primer may be bad inside and is possibly leaking fuel into the manifold. The motor runs a little rough at idle. I also had a no-start at sea, had to get towed in, then at the dock I turned the primer level to prime then back to run position, pumped up the primer ball once or twice then the motor started????? lol
I may need to rebuild the electric primer.
Any advice or experience with the primers?"
