bilge_doctor
"I installed the Edlebrocks on
"I installed the Edlebrocks on my 77 Trojan with twin 318s two seasons ago. I connected the electric choke wires to the primary side of the coils. Edlebrock does not recommend this but there was no other place that I knew of that worked with the ignition switch. The port engine runs fine. The starboard starts and warms up and then starts missing. Voltage check at the the primary side of coil shows only 3 volts and fluctuates up and down plus or minus 3-4 volts.
The boat has factory Chrysler electronic ignition. I have swapped the coils, and ignition modules from the port to starboard side and the problem stays on the starboard engine.
I can run a new wire from the dash to the choke but really am more concerned as to why the two engines are different.
Any help or suggestions will be appreciated."
