Have a 1991 searay with 4.3 mercruiser , alpha1 drive, keep blowing the ignition fuse [20 amp under the dash] , used to start ok then run using the muffs, increased the rpm , was ok ,let off on the throttle
then it would die.
Now as soon as I turn the key to run only the fuse goes + my nav light fuse to.
This past summer I forgot to put the plug in , got some water in the hull , but still started after draining , + did the mistake of starting it offshore without water supply for a few minutes
, could I have
ruined something? , it looked like I was overheating when I got back to dock.
then it would die.
