I have a 2003 Suzuki DT150 EFI
I have a 2003 Suzuki DT150 EFI no carbs. Is the motor adjusted from the factory to run rich when these motors are brand new and when you bring it in for it's first tuneup after breakin they adjust the rich/lean screw? Anytime I start the motor and let it idle for 30 seconds or more and get on the throttle it boggs the motor and will not plane out. After throttling up the first time it's like it burns the excess oil on the plugs and then I back off the throttle then back on the throttle and get up with no problem. Other than that the motor seems to run fine. Pulled the plugs and they are all dark brown and the electrodes look to have a layer of carbon on them. A ratio of 50:1 means 50 gallons of gas to 1 gallon of oil. Am I right? I need to check and see how much oil I burned on my last trip. I had the tank in the boat and oil tank on the motor both topped off and burned 17.5 gallons of gas. I'll check the oil and get back with the info.
