monterey262
The 15 amp fuse powering the ECM keeps blowing and I can't pin down a short. All the harnesses are intact and the connectors seem to be corrosion free. The SELOC wiring diagram for the 2000-01 5.7 GSi engine doesn't show my engine's fuse block but using the 4.3 diagram that appears to match, it looks like this 15 amp circuit feeds the ignition/fuel relay. Could a defective relay be causing the issue? SELOC doesn't have a troubleshooting procedure for this very frustrating issue.
If I replace the 15 amp fuse with a 20 amp it isn't blowing. My ammeter is showing an inconsistent draw, sometimes well under 15 amps (11-12) and sometimes spiking to just under 20 amps. There does not appear to be any other issues. The starter cranks normally. 1387 hours on engine; original starter and alternator. Alternator is putting out 13.2 volts at 2500 rpm with normal load (GPS, VHF). Could it be a faulty alternator diode feeding back to the relay?
Any assistance would be greatly appreciated.
