I have an early 1980 Evinrude 9.9 hp that ran perfectly and then developed some performance issues early this year, here is a rough timeline of it's performance decline and the maintenance repairs completed in an attempt to resolve the issue but has not.
Starting well and running good for the first half hour of a trip then the motor started to bog down and run half speed.
Changes the spark plugs, rebuilt the carb, appeared like maybe it was starving for fuel and the float was stuck. I also replaced the hose and hand pump and connections from the fuel tank to the motor.
Next trip the motor started well and ran good but the same thing began to happen and about a half hour into the trip the motor lost half power, motor started bogging down but still running good enough to get to my destination.
Changed fuel pump , cleaned and checked carb again, motor started but began to have problems starting and running until eventually it wouldn't start and stay running.
I walked into my garage one day and was overpowered by the gas fumes, I thought i left the cap of a gas container for fuel that i had stored for the lawnmower but it turned out to be a puddle of gas under the lower unit of this 9.9, something I haven't seen before in the 2 years that I owned this boat. All symptoms pointed to a bad fuel pump or bad fuel line or hose leaking but I checked all and replaced most hoses and the fuel pump but when I leave the fuel line hooked up to the gas tank and motor, the gas is bypassing everything and leaking out through the lower unit somehow ????
I took it to a guy who was supposedly expeienced with Evinrude motors and after explaining the issues and everyting I already did he also rebuilt the carb and replaced the fuel pump ( same stuff i did) and the guy was scratching his head the same as i was about the gas running out of the lower unit and was never able to resolve the issue, he admitted defeat and of course didn't charge me anything for his time or parts replaced which I respect and kinda felt bad for him but on the other hand he didn't do anything different than I did so that's on him.
Does anyone else out there have any other ideas on what the problem might be before I end up just calling it all bad and replacing the unit? Thanks for any ideas or suggestions you may have. Feel free to ask for more information I would appreciate any help.
Reply
Report
Reply
Report
