novice_marine
engine acts like it runs out or gas, will rev out and sound very good for a minute or so them lug down and die. it will not idle right and i can not get the idle adjusted up. but the engine is clearly not running out of fuel, you can look down the carbs and watch the main jets flow none stop untill the engine dies. and if i try to squeeze the primer bulb to get a little more fuel to it, the engine will immediatly shut down. the plugs seem to have good spark, but when you pull them, they are soaked with oil. i am mixing the gas 50:1. the engine sat for about 3-4 years before i bought it. it has NGK plugs that are flat on the electrode end, i did not write down the number sorry. it has to be something simple i'm over looking, when the engine is running, it runs great, but about the time the boat wants to come onto plane, it looses power and shuts down and won't start for a few minutes. any sugestions will be great.
