E8RCNR Discolored Float?
rbackmann
First time seeing the inside of a marine engine. Is that color normal for an old engine float? 1982
There was nothing. Some friends told me to pull the carburetor and clean it up since it was just dead silence after a pull. So I dutifully cleaned it up and put it back and it fired off on the first pull. A very satisfying feeling. The ugly float was ok I guess because I didn't replace it. It was, however, not sitting level when holding it. So I tweaked the arm a little, finished the clean up and that took care of it. I also replaced the spark plugs since the old ones sat for 2 years. but I think the issue was that float arm way out of sync. It was probably off by about 40 degrees. Thanks for the quick response by the way. I thought I might hear from someone in about 2 days or so.
