G
Gaylan Lyon
Guest
"I've aquired an older 16.
"I've aquired an older 16.5' Alumicraft with this motor, the issue I'm having is that the boat does'nt want to plane. This particular motor is tiller steered, and all the accessory hardware including me is in the rear of the boat. I've added a floor to the boat so I feel weight might an issue. The motor seems to run great, but I don't know what pitch the prop is. Can't find numbers on it at all. What is the standard prop for this motor? If the prop is the solution to my problem, which way should I go on diameter, pitch and number of blades?"
