jfields
This motor runs good for a few seconds then shuts off like it isn't getting fuel. Sometimes it will run for 5 or 10 minutes. Here is what I have replaced new on it. All fuel lines on motor including the hose and primer bulb from tank to motor , New fuel connector from primer hose to motor New fuel pump , New Carb rebuild kit , and new fuel tank. The only thing I have not replaced is the body fuel connector. This motor sit for years and the carb was a mess. I soaked it in parts cleaner overnight , ran wire through all the small holes , blew it out with air , and cleaned carb body with a steel brush before installing the new carb kit. I am in over $ 500 just on parts. Im about to count my losses and give up on it. I could go ahead and replace the body fuel connector. Could this be the problem ? Does anyone have any advise before I throw in the towel ?
