grimesinma
I have a model E90DPLSOR that frequently gives me a "No Oil" warning which puts it into limp-home mode. Shutting the motor off and re-starting clears the problem. On any given outing this may happen ten or more times so it is more than just a small nuisance. I have verified that there is oil in the tank but upon inspection I also see little air bubbles in the lines. I suspect that these are causing the faults but they might be normal. What should I do to fix this problem?
Pic:
Pic:
