P
Paul Doubleday
Guest
Have a 1990 200hp with Duo Pro
Have a 1990 200hp with Duo Prop deisel. When going along can trim out but will then loose pressure and trim in by itself. Checked and have water in oil suggesting leak in seals in rams. Someone tells me to remove rams and replace seals I must take the engine out to gain access to them (not like mercruiser where rams are external). Please tell me this is not the case to fix problem. Thanks
