Duo Prop Trim cylinder identification
pk136
I am new to the Volvo Penta outdrive world and I am having a hard time finding the correct trim cylinder.
I have a house boat with a 1994 Ford 5.0 L EFI and what I assume is the matching outdrive which is a duo prop design. The port cylinder is cracked which I need to replace. My local mechanic looked up my drive and came up with part 872612 which has the U shaped end on the shaft and mine have the cylinder shaped end.
The cylinder has a tag attached with 08W08 stamped on it and the starboard side has 08W09 onit. Are these numbers useful to trace the correct cylinder.
In addition, am I correct in saying these cylinders also prevent the drive from trimming up when placed in reverse as I can not see ant locking mechanism.
Thanks for your help
