Dual Carter YH Carberator syncing
0gravity
"Hi All,
A friend of mine has
"Hi All,
A friend of mine has a 1960 Richardson with 361 Chrysler engines with dual Carter YH carbs that were just rebuilt.
The port side engine is running strange and bogging when you throttle up quickly from idle but is fine when throttling up from a higher RPM,
there is also a slight rattling sound comming from one of the carbs at idle, I suspect that part of the problem is that the carbs might have come out of sync, does anyone know the procedure for syncing these carbs?
Thanks in advance,
Mike"
"Hi Dave,
Thanks for the repl
"Hi Dave,
Thanks for the reply, although the setup is totally different on my application I think the general principal might be the same....basically I'm getting from this, is that, with both Idle adjustment screws removed, make sure that both throttle butterfly's are completley seated closed and then set the linkage between the two carbs to the correct length? Does that sound right?
Thanks again,
Mike"
"Sorry Mike,
I'm not th
"Sorry Mike,
I'm not that familiar with this type of setup. A little before me. The page turned up on a search and I thought it might help you."
