DT85TC dies after 10min
B
Bill Smoker
Guest
"Starts, runs ok for about 10m
"Starts, runs ok for about 10minutes at full throttle, dies. After few minutes, starts ok, runs ok, dies again after a few minutes at full throttle. new plugs did not solve it. Im not a mechanic"
"Hi Bill
to go through the si
"Hi Bill
to go through the simple things:
Check your fuel system for a few things.
When it stops is the primer bulb full or empty. What you describe can be a simple as a blocked vent on the fuel tank, as fuel is drawn from the tank it must be replaced by air or a suction is developed. Check the fop of the fuel tank for a small vent that must be loosened in use to let air in."
