n2diving2003
Hit a big wave the other day on the river and the motor went to 3000 rpms, limped it back. Read a bunch of you guys comments and went to check on my problem. Turned out the oil level sensor was sruck in the full position and the wave knocked it free and the motor acted as it should by reducing the rpms. Thank goodness for self preservation. Filled the oil tank, moved the float sensor up and down and back in business. Then I suppose I created the next problem myself. while trying to figure the oil problem out by myself i checked the fuel water sep for water in the fuel, none. Then i screwed the old filter back on. bad move. the free floating debris i suppose made its way to the carbs and it started missing and sneezed a couple times.
Question: Will a cleaner like sea foam help this issue or should i just rebuild the carb. How to tell which one?
