DT6 MODEL 601 403929 ISSUE NO SPARK.
rted
Greetings from Ontario Canada,
I purchased a CDI ignition coil part number 32900-98100/101 thinking this was the problem, however I still have no spark. Wondering, did I get the correct part? or is the Magneto defective, see attached image of the 3 wire plug?
I tested the Magneto using a multimeter in the VAC and rotated the flywheel accordingly. Is the below AC voltage OK?
1) The negative to the ground wire, positive to the Red/BLACK wire and got 25 to 30 VAC
2) The negative to the ground wire, positive to the BLACK/Red wire and got 25 to 30 VAC.
How can I test the newly purchased or existing CDI unit to confirm they are OK.
Your help is greatly appreciated and God Bless.
