rattlebolt
"So the guy shows me a beautif
"So the guy shows me a beautiful little sail drive with a battery charger installed and I give him a bunch of money and take it to my boat. I fill it with fuel and start pulling the rope. And pull. And pull. I pull the plug and it's too bright to see the spark, but holding the wire with my hand against the block gives me a clear certainty that the cdi is giving the juice. I shoot some starting fluid and get some little revs at last. But no fuel is getting through the carb. So I pull the carb and find ugly gum at the lowest parts. A sailer has got to fix it on the spot with what he's got at hand right? And so I start cleaning the holes with my pattented piece of speaker wire in a cordless drill. I work over the jets. I look at the bottom of the float bowl and clean that out. And there's a needle valve down there of some sort, so I pull it out and clean it up. I didn't touch the needle in the upper section of the carb (if there is one). But I did run my improvised soft wire brush up the main jet tube. a little ways. My eyes just are not good enough to see what's supposed to be up there so I didn't strip more than an inch of insulation off. So the adjuster screw was moved and the main jet was cleaned out and the main ventury tube was cleaned partially. I put it back together to see if I had done any good thinking that the gum stayed low. And after a few pulls and a shot of ether followed quickly with the choke (pulling debris through) it started to suck gas and run. It idled like a dream. It reved up to the midrange perfectly. It went into gear and held power fine. But if I tried to open it up it bogged down completely. I tried opening up the main screw adjustment, but there's this annoying little hole at the bottom of the bowl that drips the gas out of the bowl if I turn this screw out. Is it supposed to be that way? If I open the throttle more than half way the motor starves. I've probably got enough push to run the motor for a kicker. But I want it all. Where do I set that lower adjustment screw? What do I do about the leaking fuel when I kill the engine? Obviously it doesn't leak when it's running because it's sucking air through there. I'm thinking the venturi is still plugged. Or the mix is way too rich? Help me Mr. Wizzard!!"
