DT40C 97b Spark issues
ridgy
"The motor has been sitting fo
"The motor has been sitting for about 4 months without starting. will turn over though getting no spark, checking CDI but unsure how to do so. a little help would be great, or any other ideas. cheers."
OK have discon. bl/rd wire and
OK have discon. bl/rd wire and get spark. so guessing there is a short in the kill wire some where?? how do i find that?
"If motor starts with bl/rd di
"If motor starts with bl/rd disconnected you need to check safety system IE oil limit switch, Neutral Safety switch, Dead man switch, any other you motor might have These switches should be closed you can test with a continuity checker or multimeter."
