DT140 NOT RUNNING AT WOT
K
kyle mixon
Guest
"I have a 1996 DT140 that was
"I have a 1996 DT140 that was recently purchased. I had the carbs cleaned due to it sitting up, ran fine for a couple of times now when running I hear a chirping noise when running over 3/4 to WOT the motor then bogs down and starts jumping, I can throttle down and go back into power again runs fine up to 4000 rpm's any help would be great"
took the boat out today and di
took the boat out today and discoverd that the chirping I am hearing is alarms first starts and the oil light comes on after that point the rev limiter light comes on and that is when the bogging starts any suggestions?
"Found the oil filter/sensor r
"Found the oil filter/sensor removed it and took apart had alot of sludge on the screen cleaned up and reassembled, took the boat out and ran with no problems at all. Thanks everyone for your help hope this helps someone else."
"GREAT forum!! I have a 140 Su
"GREAT forum!! I have a 140 Suzuki & had the exact problem. Cleaned the carbs, replaced the gas filter, plugs, & changed the coil on bottom cly. Still bogging at WFO. Will pull oil sensor & see if prob is corrected. Thanks"
