Dt140 carb adjustment
unclerob
Hi I have a 140hp I think it i
Hi I have a 140hp I think it is an 1986 I had problems with full throttle and found the carbs needed re done. So I did. Now how do you set up the carb air fuel mixture adjustment? I bought a carb sync. vacum gage but what are the settings?
The engine idles fine but in gear at higher rpms it spits and sputters..... I turned the adjust out 2 turns to start.
"ya, and it is also about unde
"ya, and it is also about understanding the basics before you make something worse
i do not have the specs for that motor
88 and up only
plus r u going to trust somebody over the net with specs
look over my posts, i always ask got a manual
if u can not afford a manual, i suggest selling the boat"
I am selling the boat but woul
I am selling the boat but would like to have it running well before I do!
Anybody else out there with some advice?
Question to the group, I have the 88 Dt 140. What voltage should be coming off the voltage regulators /rectifiers? I am getting 12.2 at low idle. Thought I had a problem with one of them but found the ground terminal for several grounds loose. Was at 10.5 before tightening the terminal.
