R
rinomare
Guest
" have a 1991 Suzuki Outboard
" have a 1991 Suzuki Outboard 85 HP DT85 SN (8501) 104890 with a spark problem.
about every other try I get a spark right when the starter starts, but never while it's turning.
Flywheel key is fine, all grounds cleaned, wires cleaned and reconnected on engine and control box.
When I first got it a month ago it had a bad starter; rebuilt it, then it ran fine but wasn't picking up water; replaced the impeller and it ran fine with water coming out the tell tale. Sprayed carb cleaner in the carb throat and it never picked up spark since. I changed plugs, tried different combos of plugs and coils and wires to no avail. I tested the neutral interlock and checked all connection in the control box. Disconnected the green kill switch; no change.
I think I have a bad stator, can you verify the electrical values?
I removed the stator and timing assembly and spark coils to test them more indepth.
The stator physically looks okay but the readings look questionable. One or two of the coils show some copper and I can get a 0.6 ohm reading between them.
On the three wire connector Black to Red/white show 123 ohms, red/black shows infinity to all wires. Could the red/black be an open circuit? The crimp connectors and connections at the connector look good; continuity on the meter.
Remaining stator wires:
Yellow to Red/Yellow and solid red any combination) are 0 ohms; possible short? No visible short between them.
Infinite resistance from yellow to black or red/white or red/black.
The timing assembly the inner set of coils that turn with the throttle) has two coils and 4 wires. Yellow/Red to Green is 340 ohms, pink to white/red is 340 ohms; sounds consistnt. Other combinations show no continuity.
I removed the spark coils to test them.
The coils look consistant when measuring from the colored wire to the lower or upper bolt hole, but when trying to measure from the spark plug lead to the bolt hole the meter fluctuates in the 20K range. Could this be normal or a sensative meter?
Thanks in advance for anyone with some ideas. I'll try scouring the boat for bad grounds or flakey connections tomorrow.
The Clymer manual didn't give a good description of how to test spark coils or stator I only have one colored wire on the coil, not two). I have a Seloc manual on the way.
Any other ideas? "
Any other ideas? "
