Dt 85 Emergeny Switch
neckman
How does the emergency switch
How does the emergency switch work? I thought I could eliminate it by hooking the two wires together until I checked with an ohmmeter and saw they had continuity without button pushed in. I am getting power to Ignition switch thru white wire but turning switch does not put juice to grey or pushing in does not work choke. A hot jumper wire to grey and everything works so I am thinking of putting in a universal ign switch but I am not sure how the emergency will affect it. Also do Suzuki ign switch turn to clockwise only a very little. All I hear is a click but it doesn't feel as though it is turning to star position.
sounds like u need to check th
sounds like u need to check the wiring
the ess switch grounds out the stator so motor will get no sparky
