"Firstly Hi all and hope someo
"Firstly Hi all and hope someone can help. Recently purchased a 17ft driver with a dt75 suzuki outboard approx 93. Had been stood up approx 3years when I purchased it. Removed stripped and clean carbs, replaced fuel/oil etc. My problem is (and started before the boat was layed up), Took the boat out today and all ran fine except when I drop down to tickover then try to pull away again engine stalls. will then not start unless I trim the engine right up, Then starts easily. I then have to select gear, feather throttle to increase the revs to about 1000rpm, trim back down and away. The only bad bit is from tickover to about 1000 revs. Any Ideas?
Thanks in advance Paul,"
