Dt 75 oil injected
rodamo
"Hi
I have a DT oil injected
"Hi
I have a DT oil injected 75 hp ,where can I find the year of Manufacture (is it on on the motor) ?
Rod....Aussie"
"If it helps, what color is th
"If it helps, what color is the motor? the 90's motors were a charcoal grey, and the 80's were a blue or silver. This is only what I have learned by going to the marine shops and what I have seen online. If you can find the model number this site has a way to break it down. Click on the engine parts icon, select suzuki, then scroll down to the suzuki line and pick model identification. Hope it helps."
"Thanks Brian
I went to the
"Thanks Brian
I went to the Model ID,but I must be thick,as I cant work it out, (Dt 07501-505864),I cant seem to see any reference to these nos?,Only thing i can seem to make sense of,is mine is oil injected,I think it means 1985??
Rod"
"In your model, I think the &#
"In your model, I think the "5" (as in 07501-"5"05864 indicates the year (ie 85, 95, etc). Since there was no DT75 in 1995, 1985 is probably a good guess..."
"Hey, I found the info you nee
"Hey, I found the info you needed. The year is 1985 and your model is Dt 75TCLF. If ya need prints you can find them on brownspointmarine.com click on the top parts icon and it will send you to the PDF file.good luck."
