I have a 1992 DT30c Suzuki.
It starts without any problems, and runs fine upp to approx. 1/3 throttle, then it starts to die, if I throttle up fast it revs up and works fine again.
The problem occurs at the throttle setting which resembles raising the idle-lever on the controlbox to max (without putting it in gear) No difference whether it´s in gear or not.
Tryed different settings on idle air screws, no difference.
If I leave the throttle at the position where the problem occurs, the enginge revs up and down, slowly, if I push the throttle further it dies. If I press the choke in that throttle position it dies too.
Starts again with no problems at all.
