ryans01z28
I recently bought a boat from a guy and I can't get it started. So far I've checked compression which is anywhere from 100-90psi. I took the carbs apart and did a quick spray down with carb cleaner and without replacing or taking any parts out of the carb. If I spray a shot of carb cleaner in the carbs and hit the key I can get it to run for a few seconds but that's it. Do I need to Tare the carbs all they way down and get a carb kit? I did look at carb kits but doesn't look like much than a few gaskets and 2 other small parts.
ThAnks
i have an update: I got the motor to run with car cleaner and it will start on its own now off gas but it does spudder and pop a little out of the exhaust. Do u think I should run it a little more to see if it comes out of it?
ThAnks
