"Hi I have this engine and run
"Hi I have this engine and runs good forward and reverse but only out of the water when put my boat into the water cant develop speed and power, I colocate in neutral and acelerate and the engine respond good, but when change to forward cant run and will die, the las week replace the diaphragram set for the gas pump and review the holes for the carbs assembly again but is the same, I thinks the sensor throttle is bad our not have a good adjust, some tips of the similar failure aou the how adjust this sensor I will apreciate
thanks"
thanks"
