"Just had a new 360 long block
"Just had a new 360 long block put in my 34'silverton. Before taking it off the blocks and having it hoisted in the water the young mechanic wanted to dry fire the new engine for a test. When I asked about hooking up water for cooling he said the eng. was fresh water cooled with anti freeze in a closed system, just watch the temp. gauge, shut it off at 160 degrees, we were only doing a quick test. Soon after discovered he had melted the raw water impeller. Now after fixing that and the boat in the water, when I shift the boat ingear, forward or reverse I have a horrible banging noise on each revolution of the the eng.,sounds like a bolt not tight. Pulled the inspection cover allbolts seem to be tight on the flywheel. Could the flex plate be installed backward? Could the water pump in the tranny be also burned up, even when the mech. dry fired the eng. it was not put in gear? FYI,the 71 series tranny and V-drive ran good before eng. replacement. I did unhook the prop shaft for drill and trouble still there. Noise is still there at idle or higher rpm. Thanks, Steve"
