I have an '88 Tiara 2700 with twin 350/270's. Starts fine, idles fine and runs fine right up to the point where I run for 20 minutes or so at speed and then cut back to troll on the port engine. It will stall, might take 5 minutes or might take an hour but it stalls every time. Won't restart unless I crank it for 10-20 seconds or so without opening the throttle. Then a pump of gas and she might. Sometimes. Sometimes we come home on 1. Starts right up the next day. Starboard engine is ok at all speeds.
Last time out my mechanic was fishing with me so he did some investigation after it cut out. Plenty of spark. Carb was bone dry. Choke was open. Definitely not flooded. Slight hiss of air when he cracked the fuel line at the carb. Spurt of gas when bumped over. Started after 10 second crank and 1 pump. Tightened the bolts, sprayed wd40, and watched it for a while with the spark arrester off. Carb was smoking a bit from the throat and vent holes. Plus it was making this faint and intermittent "ship, ship" sound if you put your ear down to it. Stb carb doesn't smoke or make any noise.
Boat has 1 tank, 2 welded-in pickup tubes, 10 micron filters, new rubber fuel lines in '13, rebuilt port carb in '14 to address and solve a flooding issue at troll. The pleated paper filters at the rear of the engines are not installed. Metal canisters but no filters.
Before the trip with the mechanic we had:
Replaced the port fuel pump
Cleared a bit of trash from the port anti-siphon
Removed the port anti-siphon altogether
Changed the big filters and the little screen in the fuel line
Next steps are to:
Add heat shield to the fuel line between the fuel pump and the carb
Eliminate the last of the metal lines up to the fuel pump and route them away from the engine
Swap carbs
There is zero smell of gas in the bilge at any time.
Thanks for making it this far on a long post.
I'd love to hear any suggestions
Next steps are to:
Swap carbs
