Dropping the Lower Unit on a b90 15hp
captb
"I think I must be missing whe
"I think I must be missing where the shift linkage comes apart. Any idea on where that may be on the motor described in the title?
I'm pretty good with this stuff usually, I hope I'm just overlooking something simple.
Thanks in advance."
"well, i loosened #49 because
"well, i loosened #49 because i used that same diagram and still no love.
any ideas?
motor is a '90 model, with 10 hrs on it. been sitting since '91. i'm changing the water pump before i run it too much.
i shot some pb blaster on #49 before i left it to sit overnight before i came in from the shop."
Well that's the clamp betw
Well that's the clamp between the two halves of the shift rod. You have to remove one of the bolts to pull it off though. (loosen both but remove one)
"cool, that's what i neede
"cool, that's what i needed to know!
thanks, i'll finish it up this afternoon."
