Freak4fishing
Have a question 2017 90 hp command thrust I replaced impeller with lower unit off I noticed a hole in the upper driveshaft housing this hole is right behind swivel bracket after installing lower unit back on I noticed I can see driveshaft or maybe it’s the shift shaft I am seeing is this normal or should there be a rubber plug there? I have looked at parts manual and can not find plug or cover if there is supposed to be one .
