Driveshaft Seal Replacement
S
Sleeper
Guest
Need to replace the driveshaft
Need to replace the driveshaft seals on a 1990 Johnson 225 (3 Liter SeaDrive). Forgot how the bearing plate under the driveshaft goes. Which way should the oil hole in the bearing cap face?
If the part has a groove all t
If the part has a groove all the way round to feed the oil thru the hole. then I think it does not matter.
"As Ssparky states, with the g
"As Ssparky states, with the groove feed route, the actual position doesn't matter. However, as a creature of habit, I always position the numbered portion of the housing towards the front."
