Jerryjerry05
Outstanding Contributor
2004 Yam 200 SX200TXRD
Owner stated it started turning over slow.
History: #6 low comp. but still started good and ran like nothing wrong.
Then the slow turning over started??
Checked the battery and starter, OK
Pulled plugs and still turned over slow.
So I thought the lower unit, a bearing might be locked.
I tried to pull the lower and it came off REALLLY hard.
Turns out the drive shaft passage and bushing was completely clogged with salt and corrosion.
Does the bushing need to be replaced or can I leave it out??
The boat lives on a lift in salt water and I can only think that it's gonna happen again????
Would normal flushing after running have stopped this?
No fresh water on the pier.
