Fernandodgalindo69
hi all, I have an issue. went to catalina and on the way back I used the motor as it was no wind. by the time I made it back the motor stopped working in the forward but the reverse was ok, but then the next day, it didn't work either. the motor turns out perfect, but now the forward or reverse lever is stuck and the gas throttle doesn't work. it turns on perfectly. just wont go forward or back. what do you recommend me doing to getting it fixed on my own. you guys helped me on suggesting the carb needed a good rebuild and I did it and worked like a charm. I hope you can do the same for the drive/reverse. thank you. its a tohatsu outboard 9.8 hp , 4 stroke. 1985-86. thank you again.
