RicardoMarine
Gold Medal Contributor
Bob, he does not have a 280/290 series drive. I believe that he originally thought that he had a 280/290.... (see post # 5)
He has a 1994 5.7 GI-PMDA.
You will NOT be taking the PDS Bearing off at first.
You must first remove the PDS as an assembly (PDS/bearing/small snap ring)
Look at the schematic again...... post # 6.
Look at the PDS and where the bearing is positioned on it.
The bearing is positioned on the PDS and locked in place with a small snap ring.
The PDS and Bearing as a UNIT fit into the bore of the Flywheel Cover.
The forward section fits into BOTH the Borg Warner coupler spines, and the PILOT NOSE into the crankshaft bushing.
(Unless corroded, you will not concern yourself with these)
There should be only ONE bearing on your 1994 5.7 GI-PMDA PDS.
Not two, if all is as you say re; engine model number, etc.
This means that the PDS (with bearing attached) will/should come out AFT.
No punching.... only PULLING!
(I may have suggested punching the seal out!)
Listen, any automotive type mechanic friend could very likely help you do this.
Just make sure that they have seen the schematic.
Maybe print this info out so he can read it.
Print out the schematic as well.
The only parts that will be coming out will be:
**One PDS with one bearing and small snap ring attached that you will not touch yet.... not until the PDS is on the bench.
See previous post # 27.... "the surgical procedure"
Once out, replacing the sealed bearing will be simple.
(do not install an Open bearing)
FYI; If I were you, I'd want to check the shimming of the transmission before final installation. I've seen this all too often where an owner did not receive ALL of his shims back. Shame on the shop if true.
Yes..... indeed a bummer!
NO... NO hammer whacking!They didn't say anything when I picked up the boat. Yes, I was charged a diagnostic charge. The transmission was off the boat and they did give me a bad with parts in it. I haven't looked in it so I don't know what parts are in it. The top of the drive (with the transmission removed) has a plastic bag taped to it to prevent water from entering the drive. I don't see how I'm suppose to take the PDS bearing off. Earlier I think you mentioned that it could be punched out. Do I just get a screw driver or something similar and wack it with a hammer?
