drive/ damper plates
jlkachina
Need some help
Am helping friend tear apart his 25' Baja fishing boat to rebuild stringers.Have taken out both ford 302 inboards. He wants to replace the damper plates in the transmission while he has them out. Borg/Warner tranny and flywheel diameter tooth to tooth measures 13 1/4".
Have removed the first original damper plate (triangular in shape) and it appears that has been replaced with a full round disc type. Everywhere we've looked on the web the flywheel diameter doesn't seem to match up with what we have. Boat and motor 1986. Can anyone give me a part number or send us to the right website parts dealer to make sure when we order the 2 damper plates that we get the right ones?
Jerry and JIm
Jerry and JIm ,
The Borg Warner drive couplers that you are looking for, may very well offer multiple bolt patterns.
Here is a typical and very common triangular shaped coupler.
The multi bolt pattern allows this to fit many different applications.
The center splines are Borg Warner until the cows come home.
The dampening will vary for different engines.
