91 VP 570. aftermarket 3 year old sherwood rw pump has a drip coming from it and I can't tell if its from the face plate or the shaft area. I resealed and set the o-ring, worked non drip for a few hours but the drip is back. I replace my impeller every seaon. Did some previous post searching and found out this is a common problem and it's probably a seal within the pump it self. If I have a sherwood pump what should I do next? Can i replace the gasket on the inside of the rw pump with out removing it entirely? I have limited space to work with since my fuel tank is directly in front of my rw sea pump. I usually use a mirror to look inside the rw impeller housing.
