lakedrifter
Good morning fellow boaters,
I'm currently in a full restoration of a 21ft - 1977 Searay Cuddy Cabin.
A little on how I got here. This started out as a gas tank project due to sludge in the tank. The boat would never plane out and I knew she was having issues. Once I started messing with the tank, the project went to a full restoration rather quickly. Not only did the tank have sludge in it but the floor had numerous soft spots and one complete cave-in behind the captains chair..
To catch you up:
1) The entire floor has been removed, I also found that the 2lb foam was more like 50lb foam, soaked from years of abuse
2) Gas tank removed. I found 5 pinky size holes in the aluminum gas tank. I can only assume it was caused from salt water, and I can only say that because I have noticed salt damage on the railings and other areas.
3) Engine and outdrive and all accessories removed. Something told me to check the transom. It was soaked half way up. I remove the entire transom.
Where I'm at:
1) Transom has been replaced and re-glassed. Tabbed with 1708 and 2 layers of 1708 applied
2) Stringers are tabbed in (except for in the cabin). Same method as transom.
3) I’m currently trying to mock up my engine bed
#3 brings me to my question. Does anyone have a drawing for a mock-up 228 Mercruiser engine? I think that would be easier and much safer to work with then the bare block via chain hoist.
keep it easy....
lakedrifter
To catch you up:
Where I'm at:
keep it easy....
lakedrifter
