"Rick,
Hope I'm not being
"Rick,
Hope I'm not being a pain in the butt about this transmission service, if so let me know.
Found an actual ZF Hurth maintenance and service manual on the boat this a.m., hidden behind my crusader manual.
First it says (diagram also) that the old fluid should be sucked out with a pump through the plate housing where the filter is, says to loosen the allen screw lift the filter out (replace it with a new one)and pump the fluid out through there, not the dip stick tube. Also, it says to fill it through the same opening then put the new filter back.
I checked the fluid level (cold) and it is right at the min. line on the dip stick. Manual says it should be between the lines. Approximately how much dexron would it take to bring it up to full, are we looking at an ounce or two, or several ounces ?
BTW, it sure would help if I were 5 ft. shorter and 200lbs. lighter, they don't make it easy.
richie"
