"I've just dissassembled m
"I've just dissassembled my DPSM outdrive and transom assembly and I'm pretty dissapointed with the corrosion in it and the degree of difficulty in dissassembling it considering it's only three years old and has only 150 hrs on it. I don't believe the electronic cathode system has ever worked on it from new as I've never seen any led's lit on it. It has power to it. What would you recommend assembling everything with. The guy that installed it say's he uses lanolin grease on everthing. The boat is on a trailer (never sits in the water for more than a weekend) and is thoroughly washed with fresh water and I flush with a corrosion inhibitor after every use.
Any advice welcome, Regards Peter."
