aluminator
"Was running 20 kt and then wi
"Was running 20 kt and then without warning the out drive top end exploded. The main drive gear from just passed the u-joint came apart blowing the upper case out.After checking out part list discovered the gear that came apart has a new part #. Can anyone tell me if the old part # was defected hence the new #.Oil was full, with no water in outdrive,correct oil was used,teeth on gears were not missing like it slipped. I believed it just came apart.}}}}}}"
