Hey Guys, Well more grief. Went down to the last night to prep the boat for a tuna trip. After starting, and waiting for it to come up to temp, I got off the boat and around to the stern and when I did I notice a noise. One I hadn't heard before, kinda like gears meshing, low volume and no grinding. I shut it down.
After the hurricane haul out I had some gear oil in my bellows. Made some calls and determined I couldn't make this repair easily on my own. Called the local volvo penta guys they checked it out did a pressure test ( no sure about vacuum test ) and it held for three days filled gear oil and gave it back. (when I drained the drive for transport there was very little oil and no metal on magnet).
This morning ready with a funnel and some oil (or so I thought). Found out, little to no oil on dip stick (with drive tilted enough to keep hole out of the water) and I had grabed a quart that had waste oil not fresh oil. so I pulled the plug on the trip. (bummer) But just could risk damaging the drive for a fish.
How is it possible to have a air tight drive that still leaks. BTW, when I loosened in the fill nut you could hear air getting sucked in. WTF.
Any thoughts.
Thanks Tony G.
Any thoughts.
Thanks Tony G.
