tarheeltom
I just noticed an oil leak behind the large prop and I'm not sure if it is coming from the prop shaft or the bearing housing. It really doesn't matter because if I can get this thing apart I'll replace all the seals and O rings. From looking at the schematic,it looks like I will need 2 large O rings for the bearing carrier, 2 seals for the large prop, 2 seals for the small prop and O rings for the drain and fill plugs. If anyone can think of anything else I might need to order please let me know. Also, I don't have the special tools that Volvo recommends so if anyone has done this any tips you can give would be greatly appreciated. Thanks
