Does a bad ignition coil causes low compression? I have a 50hp mercury 500 outer board that has low compression on all four cylinders. When I pulled out the sparkplug wire from the ignition coil it was burned and black particles are coming from the ignition coil. Could this be the reason for the low compression? The compression were good before and the motor was working fine before. But suddenly the motor stopped and I had tried starting it several times and couldn't get it to start. I think I fried the ignition coil but not sure if that also causes the low compression. Would replacing the ignition coil fix the compression issue?
