BrokeLoser
For a 2007 200 hp H.O. Etec
#1 hole - 118
#2 hole - 110
#3 hole - 112
#4 hole - 110
#5 hole - 110
#6 hole - 118
This is a new to me engine. The block had two pistons let go; supposedly all six cylinders were machined and sleeved. (stock bore) Supposedly all six pistons were replaced new as well as rings, wrist pins and rod bearings...a total overall...supposedly. I'm finding some information suggesting this motor should make somewhere in the 130 - 140 range, which I thought seemed high....Would a supposedly freshly rebuilt engine really only yield 118psi on the high side?
Also, when I conducted the compression test I did it by myself and although I did run the engine to operating temp I did not manually open the butterflies to WOT. How much could I expect the numbers to rise if I held the butterflies open? Just looking for an educated guess here. I intend to retest when I can recruit some help. I wanted to check with you pro's on this. Any thoughts?
#1 hole - 118
#2 hole - 110
#3 hole - 112
#4 hole - 110
#5 hole - 110
#6 hole - 118
