"Fogging means running excessi
"Fogging means running excessive oil mixture in engine to coat crank, rod bearings and cylinders. The easy way to do this is to buy a can of aerisol fogging oil, run engine on hose, spray mixture into carb till you almost stall engine. Keep it running for a couple of minutes while spraying oil into carb. It should smoke like crazy, thats good.
When done disconnect gas line, drain carb(s),change lower unit oil and add additave to gas tank.
If you can't run on hose or in tank you can run engine at ramp as long as you don't bother anyone else."
