Do i need to prime my fwc system
century19
hello got a 74 century fwc..w/
hello got a 74 century fwc..w/440 chrysler and a sherwood d55....just rebuilt it and started my boat today and no water out the exhaust....starting it on land with a (fake a lake) do i need to fill the engine with water first? i don't want to burn up the impeller...i took it off to check its still in perfect shape i killed the engine right when i saw there was no water coming out the exhaust i'm a bout to rinstall the pump just wondering if i should fill all the hoses with water before i start it again....
thanks
"David I thought your boat was
"David I thought your boat was raw water cooled? or am I missing something.
If its FWC the cooloing system has to be filled with coolant of course.
Never run the pump dry. I always put some dishwashing detergent on the impeller when installing. Set the vanes so they trail the direction of rotation, put a zip tie round the blades and cut it once the impeller is installed.
You can connect a garden hose to the raw water inlet hose inside the boat with a hose clamp for limited out of water testing, but a lot of temp and heating issues only show up out on the water.
Did you solve your manifold problem?"
well I found out that the v-dr
well I found out that the v-drive cooling assemby had a crack where it had been repaired before and was leaking some water.....so i took it out and i'm going to have it rebuilt.....I believe the manifold problem is solved with the correct thermostat and a rebuilt raw water pump but i need to put the back half of the gearbox back in before i can test that
